Originally posted by Trick Pony
Engine Problems, Need some Help?
Well that was a fun $100 wasted! Changed the FRPS and nothing, still idles horrible and misfires...I haven't any ideas what to do. I'm by far just an amateur working on cars.
I'll have it towed Monday to a ford shop, already $400 into trying to fix this and I can't keep that up.
Originally posted by JC316 View PostMy money is still on the coils.
Alright, just removed my spark plugs again...here's my findings:
The plugs on cylinders #5-8 are dirtier then the opposite cylinders. Also, a couple of the plugs insulators are pretty white compared to the others? There was oil on them as well?
One of the plug insulators was covering the electrode? Wtf? I had to push it back down.
Pic of a plug #8. Mind you these were just installed, car has only been started and idled not yet driven.
I have an 07 with Novi 2200 on it, I was having the same conditions with mine, plugs were the same, running rough and I had popping through the intake. Kept falling on its face, kept throwing bank 1&2 system lean, too rich, fuel delivery error code. And a horrible un burned gas smell. I cleaned the mass air and filter and it cleared up. I don't know if it was a fluke thing, but it's running great now. I dunno with yours, you may try and see what happens.
Originally posted by redrocket5.0 View PostI have an 07 with Novi 2200 on it, I was having the same conditions with mine, plugs were the same, running rough and I had popping through the intake. Kept falling on its face, kept throwing bank 1&2 system lean, too rich, fuel delivery error code. And a horrible un burned gas smell. I cleaned the mass air and filter and it cleared up. I don't know if it was a fluke thing, but it's running great now. I dunno with yours, you may try and see what happens.
That will cause a misfire for sure, it can be intermittent.
Originally posted by shumpertdavid View PostIf you mean that the porcelain insulator had fallen down and was covering the center electrode and touching the ground strap, then that spark plug is damaged and needs to be replaced.
Originally posted by shumpertdavid View PostAny more updates?
Just today I changed the oil ( which smelled like fuel ) and installed new spark plugs, for the previous ones were the wrong model.
Now the car is like it was before I started all this there's still the rough idle I noticed from the beginning. I still need to take it for a drive and datalog to check for misfires, etc. Also, got my hei tester yesterday so I'm going to check the coils today as well.
What I've done so far:
New Fuel Filter
New spark Plugs
New FRPS
Oil Change
Just to throw this out there. Idle air control valve maybe? Because I was having the same exact issues with my 03Gt, took off my IACV cleaned it up with carburetor cleaner reinstalled it with a new gasket car ran like new again.
I'm not trying to act like I know a lot about cars. I just wanna help anyway I can, keep us updated.
