I started noticing a lack of performance as it was getting colder along with a rougher idle. I did some data logging and found misfires on cylinders #7 & #8. Also, cylinder #8 spark during the datalog never changed like the others. The readings never fluctuated just stayed at 10.0 like there was nothing there?
Car has shown no codes as well.
I replaced the fuel filter and spark plugs, no change.
Tested resistance on the coil packs and all were fine.
Did a dry compression test and all cylinders were around 190 psi, when oil was added for the wet test psi did increase by about 10-20 psi.
After the compression test the idle seems a little rougher and it smoked quite a bit from the exhaust, one pipe more than the other. Also, smelled a bit like fuel?
I'm lost and not sure what to look for?
2007 Roush 427R with 50,000 miles. It's the 3V 4.6 with Eaton M90
Here's a pic of the old plugs:
