Could use some help changing out some valve springs
  • Could use some help changing out some valve springs
    Doing a cam swap on my 2007 suburban, and I need some help changing out the valve springs.
    Heads are off, new springs are here. Cant find a spring compressor that's worth a s@#$.
    I'm in Saginiaw, so if you know someone in Ft. Worth that can help out, let me know.
    Thanks!
      Getting them off:
      Have you "poped" the top of the retainers with a socket to break then loose from the keepers and valve.
      Place a larger than the keepers in diameter socket and hit it hard with a dead blow hammer.
      Get them on:
      PM if you need to borrow a valve spring compressor, or bring the heads over.
        Originally posted by Sleeper View Post
        Never thought of that before. That's actually pretty slick
          I've always used a large brass drift to pop the retainers free of the keepers. 5lbs of brass delivers a heck of a thump but won't scratch bend or damage a retainer.
            Saw it somewhere and saved the pic. I've never tried it but it should work.
