Wife's 99 explorer isn't blowing thru the dash vents very welll. U can hear that fan motor working like a champ. The ac air just oozes out the vents... Not like it use to. Need some guidance to get it back into tip top shape. I assume there is some flapper unit that switches the air flow direction when selected. Need some help with that. Thx.
99 exploder ac flow problems
Originally posted by Tannerm View PostOk I'll check. I've also heard the blend door. How easy or hard is it to access?
H
Originally posted by kdventura73 View PostDoes it change modes(defrost/floor/vents) ok? Or is it stuck on defrost? If it doesn't its probably the mode door is broken. If it does, quick test of the recirulation door is switch from max ac to regular ac and listen to see if the blower motor sound changes if it doesnt pull the blower motor down and see if the recirulation door is broken.
