Quick ? for the carb guys
  • Quick ? for the carb guys
    The electric fuel pump, a very generic off the shelf version, is on its way out. I'm upgrading to a Holley Blue with regulator since there are plans for engine upgrades for the vehicle. The pump that is in it right now is wired in to a 12v source that is keyed hot. That means I turn the key and it's activated and ready for duty. Holley's instructions state that a fuel pump relay, P/N 12-753, is needed. Can someone explain why, and its job? What if I were to wire in the Blue just the way the current pump is wired in?
    I'm lost when it comes to relays and I can't afford for this vehicle to be down at the moment.
    TIA
    --carlos
    TIA
    That pump may pull more than the switch can hold, so a relay (using that wire as a trigger) and a dedicated hot would give it the power it needs.
      So basically it boils down to it needing a dedicated HOT wire.
      --carlos
        Yes.
        Would it work the other way? Sure, but for how long? It would really suck for the fuel pump to overheat the ignition switch and leave you on the side of the road with few options.
          The funny thing about switches is that sometimes when they get overloaded it'll melt the contacts together instead of burning out. Meaning your pump might stay on one day which could start a fire.
          You say the cheap generic one is going out, what does this mean? Have you made sure it has a steady power supply and checked the flow/pressure? Also loose grounds will cause some strange problems.
          If the instructions call for a relay I'd use one.
            I always use a relay and put it as close to the pump as possible
            Originally posted by soap
              x2, relay, then you can use a small switch to trigger the relay
                use relay
                Vortex rear stand $75
                8.8 410s. $50
                **SKAGG NASTY**
                1990 Foxbody GT for that ass
                11 4 door
                13 FX2 White 5.0
                  Another strong vote for relay.
                    The last couple of days its sound was a little erratic. Almost like when you turn the volume of a radio up and down. Performance wise, it would stumble on take off. Once up to speed it was fine. Idle was on the rough side, as though running out of fuel. On one occasion I touched the pump and it was hot, hotter than I would call normal.
                    --carlos
                      Well, after a more detailed reading of the instructions I found a couple of sections I seemed to have overlooked. Apparently IT can be wired like the one that is in it right now but it's recommended to use a relay. So the relay is on order and the pump will be wired in with it next time I get a chance. For now, it's up and running.
                      --carlos
                        Why not run a mechanical pump?
                        Pro-Touring Build
                          Electric pump was already in there and an upgrade to electric would eventually happen.
                          --carlos
