Hot start issue
  • Hot start issue
    Car starts perfect and runs flawless when cold. After its warmed up will not start until it cools off comoletely. Changed map sensor, tps, and coolant sensor. Has fuel pressure and spark.
    Here's a rundown on the car.
    91 coupe 306 engine. Cam unknown, has procharger, billet fuel rails, sumped tank, a1000 pump mounted below tank. Tank is vented. Msd distributer. Has 45 psi fuel pressure has new plugs.
    It's a friends car and its been sitting for a couple years. The tank and pump are brand new and just installed
    It has to be a simple problem that we just aren't seeing
    Originally posted by soap
    timing issuse
      Starter getting too hot?
      Scott Ganow
      Lone Star Performance
      16300 Midway Rd
      Addison, TX 75001
      214-630-5006
        No. Turns over just fine
