Fuel cap issue
  • Fuel cap issue
    First of all, this is a '04 f150 and on the way to work today I got a "fuel cap" notification on the dash. When I get to work I noticed it was not on properly an completely. So I took it off and put it back on. Now the notification on the dash won't go off. Has anyone else had this happen?
    Sent from my SPH-L710 using Tapatalk
    --carlos
    Keep driving, it'll eventually go away.
      Yes once you recieve the SES light it will go away after a few cycles. If it does not then I would change the fuel cap, since your gasket is probably worn out to begin with.
        thanks. it went off sometime on the way home from work.
        --carlos
