Fox Body Vacuum Lines
  • Fox Body Vacuum Lines
    I have a 90 LX. I want to run the least amount of vacuum lines as possible. The car has no A/C, no smog pump, no egr. The car currently has the tree, but no other vacuum hoses at all. Can someone help me or point me in the right direction of how I need to run it all?
    Thanks,
    Scott
    Scott Ganow
    Lone Star Performance
    16300 Midway Rd
    Addison, TX 75001
    214-630-5006
    Thanks,
    Scott
    I go from the booster, to a tee, 1 hose down to the pcv and the other goes to the manifold. Then there the hvac stuff. But that's all you really need.
      HVAC stuff? not needed if you don't have any smog stuff on it.
      Line from Fuel pressure regulator to small tube on intake
      Line from intake to vacuum tree on firewall
      Line from vacuum tree to PCV valve
      Line from vacuum tree to brake booster
      All others capped off I believe if you don't have a/c, EGR, or any of that stuff.
      Carl S.
      2014 Ruby Red Premium GT A6, stock for now
      80 Coupe, Stroked 9.2" Windsor, Yates C3, Dominator, glide, 9.60s n/a, 1.27 sixty 5.48@127.8 nitrous on radials.
      9.32@128 pedaling it half track
        Awesome info! Thank you
        Scott Ganow
        16300 Midway Rd
        Addison, TX 75001
        214-630-5006
          can you pull EGR off w/o any other issues from the computer?
            From wht I understand it needs a tune for it, I plan on a tune anyway as this will be a nitrous car
            Scott Ganow
            16300 Midway Rd
            Addison, TX 75001
            214-630-5006
              No, I know this because I had a broken egr vac line and it would get shitty gas mileage. Fixed the line and the mpg came back.
              Will it change wot drivability? Nah
                For the heater/ac unit in the car. It's not part of engine vacuum but it gets in the damn way.
                  thats prob just because it was a vac leak
                    What about the heater hoses? Do I just cap off where all the heater hoses would run the. Since I don't have the heater core
                    Would I just need upper/lower radiator hoses and bypass hose?
                    Scott Ganow
                    16300 Midway Rd
                    Addison, TX 75001
                    214-630-5006
