How tall does my jack/jack stands need to be to lift with the rear axle to change the rear lower control arms?
How tall does my jack need to be?
Just enough to work comfortably. The jack is just under the lower control arm (right under the spring) to relieve tension on the bolt to rear end and to control the spring from the compression. Undo the bolt, then SLOWLY use the jack to relieve and extend the spring.
Then use the jack again to compress the spring back with the new LCA.Scott Ganow
Lone Star Performance
16300 Midway Rd
Addison, TX 75001
214-630-5006
Originally posted by 00KBGT View PostJust enough to work comfortably. The jack is just under the lower control arm (right under the spring) to relieve tension on the bolt to rear end and to control the spring from the compression. Undo the bolt, then SLOWLY use the jack to relieve and extend the spring.
If you're just talking about changing the lower control arms, any jack and jackstands will get the tires off the ground if you put it under the diff. Just jack it up from under the pumpkin, put the jackstands under the axle tubes, then use the jack under the control arm as mentioned before.Atlantic Blue '00 - '03 Cobra motor and TKO600, solid axle, full MM suspension
