Tig Weld Carb?
  • Tig Weld Carb?
    I have a old carb off a Polaris atv that the float arm is broke off at the base. Can I has a person to weld this back for me? Hopefully close to Roanoke.
    You can call me at 817-713-2994
    Thank ya, Wayne
    Photobucket
    I've tried that before. Doesn't work. eBay
    Originally posted by soap
      that cast stuff is so hard to deal with, as soon as you get it hot enough, it vaporizes.
      pinto gt with wood trim
        Is what I thought. I even took it to a jewlers and they couldnt weld it either. Damn carb is 575.00!
        JB Weld?
        Photobucket
          Can you braze it ?
          Big Rooster Racing
            Braze it, post the materials and i'll show you a perfect 'silv-alloy rod to use.
            THE BAD HOMBRE
              jb weld the bitch. seems to work well on cold welds. not so much in high temp areas..on second thought if that crap comes apart in the carb it wont work...buy a new one
