Ok. So after all the other minor set backs, I'm now to one I'm not sure how to fix.
There is a straight vacuum fitting right at the bottom of the intake:
And it will not allow the intake to set onto the lower. Almost 1/2 inch
There are only a few vacuum ports on the upper intake, the one one the bottom for pcv Valve??? And 2 more right behind the throttle body, which I assume is for the fuel regulator and brake booster.
But I'm not sure if that's a good place for vacuum or not.
Any help needed it's literally my only set back..
