Well, looks like my parking lot diagnostics were off, I knew the fuel pump was not priming, but with a pretty much dead battery (from my buddy cranking it over and over) and no test light, I just went off the fact that the pump was not pushing any fuel and that the car just died out of nowhere.
Put a new pump in tonight and nothing, it won't push fuel either
. I didn't have a test light to see what's going on tonight either.
Anyone know any common problems? I tried swapping relays with known good ones. Buddy ended up confessing being about 15k over due on an oil change and I noticed there is coolant leaking from the rear of the engine somewhere down the oil pan. Car also doesn't sound normal when cranking it over. I am at s loss, next step is going to be to put a test light on it and see if the pump is getting voltage (I presume it is not).
I don't know much about 4 cly 1997 camrys so any insight would be great.
