Charging issue - electrical folks please read
    Hopefully none. If there is a poor ground you'll see it as resistance in the cable. I try to eliminate the easy stuff first.
    dont downshift!!
      It will be Fri afternoon before I will be able to go spend time with it again.
      Will check and update as I go.
      Thanks again!!
      86 SVO
        With charging issues, stuff like that ( when you have a new alternator, new battery) tends to manifest itself in the form of bad grounds.
        dont downshift!!
          Ohm the negative cable to the body and engine, as well as the positive cable to the alternator, both cables disconnected from the battery.
          If they both check out, hook them back to the battery, turn the key on and check the two other smaller wires coming off the alternator. They both need to have power in order for the alternator to produce voltage. If all of that checks out fine, you have a bad alternator.
            by anychance does it have a external voltage regulator if so replace it and see if that works when i first got my mark vii it wouldnt chare the battery and i had the altenator checked and it was good battery was good it turned ouit to be a voltage regulator.
            Alex
              Alex
              No it does not. It's located on the alternator.
              Good thought though.
              86 SVO
                So it turned out to be a simple issue. The wire coming from the alt to the battery had broken inside the shielding so I couldn't see it.
                Volt meter found the break. Wire replaced and viola the charging system works perfectly.
                Now to bleed the brakes and its on the road.
                Cheapest running project I've had so far!
                Thanks for all the input. The updated & extra grounds will pay off in the long run I'm sure.
                86 SVO
                  Congrats bud.
                    Originally posted by TEAMJACOB View Post
                    Congrats bud.
                    Thanks!
                    And as far as I know so far, I believe it has all the dowel pins in it.
                    86 SVO
                      Glad it was simple. Post pics.
                        I will. It ain't no beauty queen!!
                        Picked it up through Ft Worth impound auction CHEAP!
                        Clean, fix, & flip is the plan on it.
                        Might keep it for a while though. Still undecided.
                        Soon as I get it home and cleaned up I will post up some pics.
                        86 SVO
                          Nice! Glad to hear you got it going.
                          Rich
                            Originally posted by 1fast4 View Post
                            Thanks!
                            Lol good to know.
