Maximum wheel and tire size?
  • Maximum wheel and tire size?
    What is the biggest tire I can fit on a stock 85 mustang with stock length rear end? What I want to do is use a 275/50r15 drag radial on a 10" wheel. If this will work, what back spacing on the wheel? I have an 8" wheel now with a 255/50r15 drag radial now that works pretty good, just looking to put a little more rubber on the ground. Thanks
    Hold on.........
    ./ ____ _ _\.
    (]]]_ o _[[[)
    \o_FORD_o/
    |__|.....|__|
    God closes doors no man can open, God opens doors no man can close. Revelations 3:7-8
      ........it may get bumpy before you get the answer you are looking for. Make sure you apply your skin thickening cream...
      Now, post terts or GTFO!!!
        Get ready for a little bit of newb hazing, just don't act like a retard and it will pass shortly.
        A 275 size tire is about the biggest that will fit without rolling the fenders, also put it on a 9 inch wheel...it's a much better fit for a 275.
        Detailing is an Obsession!!
        1996 MYSTIC Cobra #405 of 2000
        Fox Coupe "Calypso Killer"
          I'm thinking a 34DD will fit in there nicely!
            But I think you need a 6.5 backspace wheel if you run a 10inch rim. And the hell with rolling fenders, cut the lip off. Just have to try it and test fit it. may have to beat the inner fenders a little.
              I fit a 315 by rmoving the quads, rolling the lips and using a BFH.
              Motherfucker!!!
              Ded
                10" wheel is wide enough for a 315 easily, no need to go that wide as previously mentioned. I run 295's on a 9" wheel.
                  Thanks The 255's are working good on motor , but with a 175 shot delayed out .50 it spun the tires. Wanting to go up to 225 shot, but I think I will have to delay it out further
                    Is this a built motor?
                      Steel headed big block chevy
                        Im running a 27/10.5/15 under my 89 and I didnt roll the fenders just removed the quad shock.
                        Street car.
                          I have the quad shocks off and have plenty of room with the 255's. I just wasn't sure what my best bet was as far as wheel size and tire size. My nitrous is on a digiset so I can't ramp it in. Thanks for the help
                            15x10. 6.5 bs. 275/60/15. All day long on stock foxbody width. BFH inside and roll fender lips.
                            Don't "cut" the lips unless you want gashed up tires.
                            One day at a time.
                              Im running 275/40/17 on 17x10 cobra r's on my 89 coupe and im sliceing & shaveing peices of tire off when in hit a hard bump.
                              Ace Duce
                              I can't play in the deep end of the sandbox, that's where the leprechaun is and he tells me to burn things!
