Optima Battery ?
  • Optima Battery ?
    I have a Red Top with both Top and side post,
    anyone know if i can use both Positive side and top post at the same time?,
    reason I have battery in the rear want to run separate lines to
    starter solenoid and alternator.
    can't see why not
      You can. It is pretty common on emergency vehicles.
      Originally posted by Sean88gt
      As always, my criticisms should never be taken as if I wouldn't go balls deep in it.
        I think if they have both you do not want to use the side ones for any real load. I blew the side posts right out of two yellow tops cranking my Diesel one time.
        Whos your Daddy?
          This, it's how we drew power on the police cars when I helped out on new installs.
            My idea is to have the alternator feed into + side post,
            and + Top to starter solenoid. Foxbody with 3g alternator.
            Just to avoid the excessive wires into same terminal.
            Thanks for the help
              You can send the alternator lead to the solenoid also.
                Yes, I do it all the time.
