The clutch in my 2001 Accord started acting up. It will randomly not want to go in gear, sometimes the pedal will stick to the floor, and the engage point feels different all the time. I'm pretty sure there is air in the system.
I checked the fluid level and it is good. No leaks.
A visual inspection shows that the hydraulic line going into the slave cylinder has play in it. I'm pretty sure it's not supposed to. The threaded fittings are tight. There is a hole right by it, and I think there should be a pin in there, which there isn’t one. I can push a small allen wrench straight through the hole.
Will someone familiar with Hondas please take a look at this short video I took? And will you confirm if the pin (part #4) in the attached picture is what I need to fix my problem? I know I'll need to bleed the system once I get the problem resolved. This is my daily and I need to fix it this weekend. Any help is greatly appreciated. Thanks!
