Search in Tech only
The Garage
Tech
Puddle of water under car...
danielhv
May 2003
03-25-2012, 08:40 PM
There is a little drain looking hole in the firewall that has been dripping water for the past 4 hours, which resulted in quite a large puddle of water under my car... thoughts?
Vertnut
Nov 2001
03-25-2012, 08:47 PM
Passenger side firewall? Heater core. Although once my little bypass hose had a hole in it and it leaked just like a heater core would.
Buick355
Jan 2001
03-25-2012, 08:50 PM
Run your cars nose in it and then hit it with a rolled up newspaper.
water or coolant? Could be a semi clogged hvac drain hose. The hvac box fills with condensation and drips slowly when parked until empty.
FoxBodyNick
Iron Head
Nov 2010
03-25-2012, 08:52 PM
Originally posted by
Buick355
works everytime.
1993 Vibrant Red Cobra #1741.
71chevellejohn
my Maserati does 185
Mar 2006
03-25-2012, 08:53 PM
Is it not condensation from the AC system?
(I'm not sure where it drains on a Mustang because mine was never hooked up.)
Blackpony
Feb 2011
03-25-2012, 09:15 PM
Heater core is bad.
jakesford
Unity....
Dec 2002
03-25-2012, 09:33 PM
Yeah probably heater core, you should be able to smell the antifreeze and usually you would get some fogging on the passenger side of the windshield.
Have you changed the heater core hoses anytime recently?
dville_gt
top alcohol funny car
Jan 2002
03-25-2012, 10:16 PM
heater core or a/c condensation. should be pretty easy to tell which is which.
