power mirror switch
  • power mirror switch
    anyone have one for a 93 mustang i can use for 2 seconds? i just need to plug in one that is known to work to see if thats the problem with mine
    Originally posted by DOHCTR
    Just take a small piece of wire and jump it on two contact points if no one has one.
    Whos your Daddy?
      I had trouble with mine and found it to be a loose connection in the wire harness. I don't think the switches give much trouble. Spray the switch with some contact cleaner. They do get dirty inside since the are somewhat open to the top.
        i have some
