Good or bad? Any body run it? I got a good deal on a case of 10w30 was gonna try it out. Thanx for feedback.
Anybody use Royal Purple synthetic oil?
That's all I've used in mine since the 1st oil change and I've got 51k miles. I've got RP in the engine, tranny, and pumpkin. Have to use the Ford friction modifier in the gear oil though. It's really good stuff, just pricey.Whippled '06 by Gearheads - 474rwhp 450rwtq @ 10psi and a few other Borla/Steeda/BMR/CHE/Tokico mods...
Gearheads Dyno Video
I wouldnt use it in a motor than consumes any amount of oil. Check levels when you fill up unless you know its not an issue for you. My last truck used two quarts of royal purple between oil changes. Never had an issue with mobil 1 When I drove gas trucks.Originally posted by Sean88gtAs always, my criticisms should never be taken as if I wouldn't go balls deep in it.
Originally posted by Grape View Postif you are going to spend $10/quart on oil, there are much better options out thereOriginally posted by SilverbackLook all you want, she can't find anyone else who treats her as bad as I do, and I keep her self esteem so low, she wouldn't think twice about going anywhere else.
Originally posted by Blackpony View PostI have never run the motor oil but the one time I used their ATF in my t5, it foamed up thus killing my trans. I will never again use their ATF. We use their gear oil At the shop with great results.
