f150 5.4 running rough. need help
  • f150 5.4 running rough. need help
    05 f150 5.4 125k miles. idling rough and shows codes p0021 and p0012 which is variable cam timing retarded on bank 1 and advanced on bank 2. only thing ive found says change the oil, which didnt help
    certified deisel mechanic
    Cam phaser or cma phaser sensor. I I had the same thing happen with my 05 and it spent 3 days in my garage getting new phasers. I figured since the timing cover was off may as well rep[lace it all. So it got new chains,tensioners,guides, phaser's and phaser sensors. Runs great now. My cost doing it myself was around 1100.00 but that is way cheaper then the Stealer prices.
      sounds like thats what i'm gonna need. where did you get your parts from
        Pm me if you'd like someone to tackle the labor
          I got all my parts at 5star in NRH, the gave the sdame prices as tousley ford's online prices.
            vct sounds like a pita. one more thing to break
              Get the wedge so you do not have to pull the front cover, saves some time.
                probably low on fuel....that seems to be a common issue with 5.4's.
                70' Chevelle RagTop
                (Forever Under Construction)
                  took it to the dealer. they said it needs a new engine. the guides, phasers, chains, solenoids and sensors are bad and the topend is full of sludge. they said thats it'll be about $2k to fix it but it might lock up later down the road because of the sludge problem.
                  Rearend is whining too so i guess its time for a new truck
                    of course they told you that. Id talk to greenbullitt before you make a decision.
                      QFT....Greenbullit knows his stuff. Thanks to him I'm doing the timesert spark plug repair on my M-N-L's Expy.
                      92 LX 5.0
