starter problem
  • starter problem
    I have a Foxbody that the starter is staying engaged after starting. The starter is about a year old. Is the starter relay causing this? The starter has never sounded right since I installed it. Is it possible that I have the starter relay wired wrong?
    hit the relay if it stops its the relay
      Went thru this, if you got anything other than a motorcraft one....very possible it could be the problem, also the ignition switch.
        mine will do it some times if the battery is low.
        Doug
        90 LX Coupe 5.0
        90 7up Vert. 5.0
          same here just tap it with a screw driver
            yeap...
            Doug
            90 LX Coupe 5.0
            90 7up Vert. 5.0
              Well, I installed a new motor craft starter relay and it is still doing it. How to I determine the problem? If it is the ignition, how do I determine this? I,m sure it is the stock switch. Is there anything else that can keep the starter engaged like a short or something?
                Next time it gets hung up carefully pull the "S" wire off the relay. If it stays engaged then it is not your ignition switch, it is the relay... again. BTDT.
                or this:
                and definitely this:
                  When the starter stays engaged I can turn the key forward and it stops. I replaced the starter relay already but it is still doing it. I haven't tried pulling the "S" wire yet. Right now it is an infrequent occurrence. I'm fairly sure I had the ignition switch replaced in the last 5 years by Ford as a result of the recall.
                  Can it be happening as a result of a short or a bad starter solenoid? I just don't want to start throwing parts at it. I did this with the starter relay. What is the best way to trouble shoot the problem.
                    be POSITIVE THE TRANNY is NOT in gear
                      this is an intermittent problem. Would an ignition switch produce an intermittent problem?
                        yup. i had the same problem on my fairmont and we patched the problem by adding a push button start.
                          One of my old coupes would do that. Bendix in the starter was hanging. It sound engaged because it continues to turn with the flywheel and does not retract out. Replaced starter and all was well. On a '92
                            This^^^.
