HELP all lights went out
  • HELP all lights went out
    When driving home. All lights and my radio and everything cut out while driving. 89 Gt. It did not change the way it handled. Any idea where to start? Thanks
    SCREW CANADA!!!
    dimmer or headlight switch?
      I will check. But everything is out. Headlights, radio, interior, brake lights I mean it's dark and my gauge lights are out too
      SCREW CANADA!!!
        Headlight switch, wiring, or multifunction switch(turn signal/wiper lever).
        The wiring is under rated from the factory - over time the heat starts melting the plugs/wiring - it goes faster when the fog lights are used.
        Oh, check the fuses too.
        EDIT - didn't pay attention when reading the first time that the radio went out too.
          I'm wondering if it is a fuse under the hood. I never heard a pop on the inside
          SCREW CANADA!!!
            maybe check for a fusible link coming off the starter solenoid.
            Doug
            90 LX Coupe 5.0
            90 7up Vert. 5.0
              Bingo!
                Here is what I have done so far. Found the number 1 fuse (stop/hazard speed control high mount lamp) blown and fuse 15 (fog lamps) blown. Replaced both still nothing. Tried new headlight switch from Autozone. Nothing. I guess the fuse link at starter is next. Would it be attached to the top bolt (closest to engine block) or bottom bolt (closest to the ground)????
                SCREW CANADA!!!
                  Radio doesn't work, headlights dont work, high beams only work when u pull them back not when u want to put forward and lock in. Turn signal works as well. Such a wires problem
                  SCREW CANADA!!!
                    I suspect a bad (separating) ignition switch in the column. Not the key switch (what you put your key into) but the actual ignition switch itself. They are notorious for coming apart in '80s/90s Fords.
                      I just had the ignition switch replaced two weeks ago at the dealership for the warranty recall back in 89 for free
                      SCREW CANADA!!!
                        Might want to check up and see if they do good work.
                        (insert link to local shop / transmission thread)
                          Will do. It wa the Bankston Ford in Frisco. Off of 121/Dallas tollway
                          SCREW CANADA!!!
                            Cig lighter don't work either. FML
                            SCREW CANADA!!!
                              #16 20 amp fuse in the fuse box, also runs horn. Did you check the multi function sw for the headlight probs yet?
