Fuel return line.
  • Fuel return line.
    Are the fuel return lines on the frame rail the same on a coupe and a Gt?
    Mine Is smashed closed and looks to have been for awhile.
    With it Closed, that would just boost fuel pressure up ALOT right?
    Where does the fuel go?
    it feeds back into the tank. sounds like someone didnt want to invest in a fpr.
      Kid smashed it on a lift at school a few months back.
      Just now catching it.
        How the fuck did he manage that...
          Looks like the lift pad slipped off the rail and onto the lines.
          I got it fixed as good as I can without repairing it.
          I cant replace the whole lines because of my subframe connecters.
            Its a return line. Just cut it and flare both ends and install some rubber hose and some good clamps. Should be about 5/16 or so. It has very little pressure compared to the feed line.
              Rookie
                Are you experiencing fuel pressure problems?
                  Havent checked, but it's running alot better
                    I would check fp, if its not affecting it, I wouldnt sweat it
