need help. with my AR build....
  • need help. with my AR build....
    im trying to instill the barrel however...
    the NEW barrel i purchased. had the gas block already on it. SO how do i instill the gas tube without removing gas block???
    sigpic๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„
    ๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„๐Ÿ„
    the NEW barrel i purchased. had the gas blocl already on it. SO how do i instill the gas tube without removing gas block???
    Depends on barrel length and even still I am not sure if you can. Thinking about it I am almost 90% you can not. I don't think you can send the tube through the nut and receiver far enough at an angle to get it past the gas block.
      im going to try that. im also thinking about pulling the BCG out. that may give me more room, thanks
        BCG must come out for sure
          it's working. im have the tube half way in. im taken copenhagen brake now,
            ok it worked great... she's all done!!! i'll post pictures tomorrow,
