Going through concrete deck,Jackhammer?
  • Going through concrete deck,Jackhammer?
    Needing to go through a 6'' concrete deck to repair some plumbing underneth..I need to make a hole thats about 18'' across
    I seen that Home Depot has an Electric jackhammer to rent, has anyone used one of these electric hammers and is this the best way to get through the deck??
    Thanks
    be a man use a sledge hammer lol
      that bosch 75 and 90 lb will be ok, i d rather use a smaller chipping hammer that hits faster, or saw cut it and pop it ou
      first class white trash
        For a small whole I would just get small chop saw with a concrete blade.
          This
          86 SVO - Sold
          '03 F150 Supercrew - Sold
          01 TJ - new toy - Sold
          65 F100 (460 + C6) - Sold
            Is this a post-tension slab or rebar/steel? My point is: do you have to worry about hitting cables.
              its rebar I think
                Originally posted by black50 View Post
                its rebar I think
                That's good. If there's any question, you can walk around the house and look for cable "plugs" (the cable ends are concreted over). You really don't want to hit (and snap) a cable.
                  Yep, walk around the slab and look for grout pockets. You damn sure don't want to hit a PT cable otherwise you'll be hate'n life. Even if it it PT the deck may have been poured separate of the house foundation. If you don't have to worry about PT cables I would saw cut it, it will make for a cleaner repair afterwards.
                  The Daily
                  10' F250 FX4 CC spatanized & deleted
