The home made garage tools thread got me thinking.
I'm not sure if this would belong here, or the pic/vid..
First off, I don't call myself a carpenter.
I slapped this thing together when I moved in here, because working on the floor got old quickly.
All of the 2x4's are squeezed together with about 5 pieces of all-thread running through all of them. The 2x4 that you see is simply a cover to hide the all-thread. The plan was to sand the top smooth like a butcher block, but I don't know anything about lumber, and I quickly learned white pine would just gouge instantly. I use this masonite as a simple, and easily replaceable cover to protect the wood.
Found the wrenches for $1 at the pate, they made decent handles.
Also, on the side shot, you can see that all the 2x4''s are not exactly lined up. I wasnt too concerned since I was going to sand them down. The masonite helps.
Constructive criticism is welcome, as well as posting your own handy work.
I'd like to see what some of you guys have come up with.
My buddy loaned me a crackle box. And I wanted to try my hand at a little welding. Tacked it together for my first welding project. I was going to trim the top plate to fit squarely, but there is no need. The added work space is nice. I realize the pads for the casters are probably the weak spot, but I didnt know what I was doing. It's supported a t-5, and my body weight.
The casters are from harbor fright, and suck dick. Its all 2'' angle, except for the bottom shelf, which is 1x1''.
