A lot of you already know about this project, but most don't - it's different that what you've probably seen me post in the past, but here it is. This is a Industrial Hobbies mill clone sold by a company called Machine Tools Warehouse out of Canada. This is one of the biggest "benchtop" milling machines you can find - The travels are 31" x, 12" y, and 16" z.
The machine is purchased in a regular ol' manual machine form, with NO options etc. It's basic as basic as can be, but still pretty useful. I've had it nearly a year now and use it VERY often. The "conversion" process is pretty intense, but a fun project. I must admit, the electronics part of it was pretty intimidating for me, but with the help of "Mark04" that was pretty easy...
Once completed it will have programmable spindle control, flood coolant, 100-6500RPM spindle speeds, Threading, 4 axis ability, FULL 3D machining, it should be able to rapid travers about 350-400IPM, and machine in the 100 IPM range on aluminum etc.
The semi-technical aspect:
3HP spindle motor (will probably get changed to VFD control)
72V power supply for the servos
4 axis Keling 1125oz./in servo motors
Gecko 320X drivers
CNC4PC C23 break out board and electronics (jog pendant, relay board etc.)
Warp9 Smooth stepper USB board (Converts Parallel communication to USB)
This is the machine now, sitting on a basic stand with nothing done - this was done just so it can be used. Once the conversion is complete, it will have a full enclosure with flood coolant etc.
To put it in perspective, that shelf is 6' off the ground and the machine weighs in at 1000#.
This is most of the electronic part, dummied up on a board for ease of wiring and testing.
Gecko 320X drivers
