Clutch problem?
  • Clutch problem?
    This cable clutch on the mustangs is something I'm not used to. After a hard run the pressure gets easier and I smell burnt plastic/hair and it looses much boost inbetween shifts, like it's slipping and then grabbing. So am I describing a bad clutch?
    2008 550i
    2007 ZX-14
    2007 Lincoln Mark LT
    2006 GSX-R1300 for sale (make offer)
    2002 RC-51 for sale ($1500 needs new tank)
    1995 Terminated SN95
    what kind of car is it?
    Big Rooster Racing
    1985 Mustang GT
      Sounds like it. You need a better clutch set. Don't forget to resurface flywheel.
        95 GT with terminator motor and t-56
        2008 550i
        2007 ZX-14
          sounds like the clutch is bad or the cable isnt allowing the clutch to engage all the way.
            A slow car.
              cable sounds a little too tight, you did use a longer one for the swap not the stock 95 cable correct? also are you using the stock quadrant? pull pedal up towards you and see if it will *click* and reset
                Thanks for the help, guys. It has bigger issues than the clutch. Taking it back to GHP, in a few weeks and let them sort it out.
                2008 550i
                2007 ZX-14
