I washed my engine at the carwash in my 95MX6. It immediately sputtered out of the carwash and got better somewhat, now it occasionally runs rough and then smooth out. It will be running smooth but if I shut off the engine it will run rough and smooth out after a while, the only code I get is the rear o2 sensor, but it is about 2 months old. Maybe water in the wiring? Should I start tearing into it or wait a few more days? I already checked plug wires and other connections around the intake.
Need help with my DD
When you shut it off it probably was sucking water in somewhere as it cools and then running rough until the water dries. It should go away after you drive it for a bit if that's the case.Atlantic Blue '00 - '03 Cobra motor and TKO600, solid axle, full MM suspension
Doesn't seem like a cylinder misfire, but maybe timing advance/ retard issue? After a few secs it will smooth out at idle but rough/hesitate upon acceleration then smooth out about3-4k rpm and return if I come off the pedal for a while to slow down, maybe got in the disty through the wire connections? Iwill air it out and see.
Water probably made it into the spark plug tubes. Driving it like that will ruin the plugs.Originally posted by jfrog View PostDoesn't seem like a cylinder misfire, but maybe timing advance/ retard issue? After a few secs it will smooth out at idle but rough/hesitate upon acceleration then smooth out about3-4k rpm and return if I come off the pedal for a while to slow down, maybe got in the disty through the wire connections? Iwill air it out and see.
