347 help.
    I made 617 base with a 356 ci SBC.
    And that was with some junk !!!!!
    I'm tellin ya its there if ya look !
      QUIT THINKING SMALL !!!!!
      Its an air pump ! Make it breath !!!!!
        Originally posted by holeshot View Post
        I can make that with a 306 at 10:1 comp.
        Come on guys, the technology is out there if your willing to do some research
        Or just ask the right person.
        What do you suggest then ?
        07 GT500
        05 SRT10
        88 turbocoupe T-bird
        93 Cobra
        86 coupe
        Ducati 848
          Originally posted by Blackpony View Post
          Yes and a much better head. They flow better out of the box, and with a small amount of port work, are incredible!! the port design is also much better.. you would need to buy the cnc version victor jr to be a comparable to the afr 205, so at that price point you are are level grounds... What vehicle is this in?
          95 gt
          Afr205 around 1,800
          Victor jr 1,400
          Fox lake stage 1 victor jr 1,595
          Tough decision
          07 GT500
          05 SRT10
          93 Cobra
          86 coupe
          Ducati 848
            It's an air pump that'll crack in half if you spin it too hard
            ...and where's the love for High Ports???
              IDK !!!those are definitely some badass heads, old school or not !
              Vortex rear stand $75
              8.8 410s. $50
              **SKAGG NASTY**
              1990 Foxbody GT for that ass
              11 4 door
              13 FX2 White 5.0
                Originally posted by cmltoe View Post
                I'd say vic jr's, those are going on my 306 with a little spray.
                I'd say it would run good on a decent amount of spray, but it would be a turd on motor, unless its a big cam, hc motor. You need about a 170cc head to run good on a pump gas 306 motor.
                8.8 410s. $50
                **SKAGG NASTY**
                11 4 door
                13 FX2 White 5.0
                  Yes, I build RACING engines.
                  I've got a cast iron head 355 that's tagged at 420+ BHP and its a daily driver.
                  I'm not tryin to BS anyone, I'm just tryin to say that the HP is there, ya just gotta
                  Get the right set up and equipment.
                  Tip #1: start looking at some of the cars running in Stock class NHRA ! They fly and their stock !!!!!!!
                    Originally posted by thesource View Post
                    I doubt it unless its either (a) got a power adder or (b) a serious race type engine.
                    460-480 crank hp from 306 cid is asking a lot from an engine regardless of design. You are talking a 7500 rpm, solid roller, high compression setup or using a power adder.
                    the 2011 GT's are making over 400 to the tire with simple bolt ons all day with only 302ci
                    2011 Mustang GT
                      I would look for a set of used Victor Jr heads that can be bought bare, or new heads that are bare. Upgrade with the correct springs for your camshaft application. The AFR's and the Vic Jr's will get your 347 to 400rwhp with the correct camshaft, compression,exhaust size, and intake. If you were patient I'll bet you could find some used Vic Jr heads bare for about $700-$800, throw some LaFerra or similar valves, plus a set of springs for $1100-1300. Everything will be fresh, and the springs will match your camshaft exactly. Keep the compression at 10.5 or 11.0. Put a converted Vic Jr or Vic intake with elbow, and 90mm tb. Throw some 1 3/4 headers in the mix and you will easily get your 400 rwhp. Better locate a good tuner or figure it out for yourself first. You will def need it to make that combo a civil daily driver.
                        There ya go ! If its a daily driver, hyd roller
                        Weekend warrior or racecar, solid roller !
                        PM me for any other Q&A's.
                        Somethings are not for the weak to hear !!!!
                        LOL !
                          Who do you build "RACING" engines for? spill the beans or shut the fuck up about it.
                          Hell I just made 550+ flywheel threw EQ heads and a q~jet on a 350. twisting a flat tappet 7.5k.
                          You can make power out of anything.
                            was wondering where you were
                            8.8 410s. $50
                            **SKAGG NASTY**
                            11 4 door
                            13 FX2 White 5.0
                              At what RPM? And what is the compression ratio on the Coyote engine?
                              Get back to me on it and then we can apply that to a 2v old school 302 design.........
                                AFR 205s and the 282 is a good set up.
