Shift Solenoids PA Full Manual Valvebody
  • Shift Solenoids PA Full Manual Valvebody
    To activate overdrive I apply power to SS1 and SS2 at the same time, yes? What do I do with SS VPWR?
    To activate converter lockout, I ground TCC and apply power to TCC VPWR?
    Thanks,
    J
    '95 GT
    I fucked the Olsen twins before they were famous.
    The way I read it is to connect SS1, SS2 and TCC all to a ground source. Then connect VPWR and VPWRTCC to a switch to supply 12V when you want to use overdrive and converter lockup. It recommends that you use them together.
      what are you trying to do?
        Overdrive and converter lockup.
        What Cat D said makes sense. I'm probably just reading the directions wrong.
        '95 GT
          I would not lock the convertor at the same time, I would lock it after the od shift imo
            Yeah I already set up the switch panel in the ash tray location I just have to figure out what to power and what to ground. I have one switch for OD, one switch for Lockup and one switch that ties the two together on the first switch. I might end up setting up a 2 second timer so that one switch will activate overdrive and then 2 seconds later lock the converter. Like you, I do not like the idea of shifting and locking up at the same time. It just doesn't seem like good practice.
            J
            '95 GT
