Anyone have anything that can reasonably calculate this? I've been through a ton of searches on the land speed sites and haven't found what I'm looking for.
Standing mile Horsepower to weight = speed formula?
Originally posted by STRONGNUFF View Post
All of the forumlas are for the 1/4 mile that I can see. I'm math retarded.
Standing mile = drag racing?
I'm asking because weight is not a major factor in top speed. Most LSR cars are surpisingly heavy. That makes sense though, as they are looking for stability at all costs and have six miles to accelerate.
Read this article and there is a calculator at the bottom.
Bonneville, Harley-Davidson, Turbo, Hayabusa, ZX-12, Suzuki, Kawasaki, streamliner, RB Racing, ORCA, frontal area, Cd, coefficient of drag
Coefficient of Drag (Cd): .38
Frontal area (sq. ft.): 40
Vehicle and Rider Weight (lbs): 3600
Speed (mph): 150
Horsepower Needed: 325.1764
Horsepower Lost to Drag: 256.5When the government pays, the government controls.
http://www.rbracing-rsr.com/aerohpcalc.html
I'm trying to get an estimate of what speed my car will be at under full throttle at the mile marker from a standing start. I want to aim for around 135 for the flats, and need some sort of baseline estimate. Going to check out the link.
Great link above 46Tbird. From what I could find online, the drag coefficient is .36 and frontal area is 22.5 for your car eric. I have no idea what you car weighs but some where around 3400 would be my guess, which works out to be 194 hp required to get to 140mph.2012 SRT8 Challenger 392 Hemi-6 speed
Speedlogix Catch Can
Resonator Delete
Originally posted by STRONGNUFF View PostGreat link above 46Tbird. From what I could find online, the drag coefficient is .36 and frontal area is 22.5 for your car eric. I have no idea what you car weighs but some where around 3400 would be my guess, which works out to be 194 hp required to get to 140mph.
I found 21.24. I guess 3700 pounds with me in it being a vert. What do you think Danny? The top speed of a 99-04 GT is rated at 139, and the car would probably put down about 230 to the wheels in stock trim, which it might as well be. If this is accurate, I can concentrate on suspension upgrades and maybe a couple of minor bolt ons like a short belt and what not.
Originally posted by 46Tbird View PostActually, I was thinking it was low.When you factor in wide tires, mirrors, etc. it all adds up.
But when I think about it, I guess that sounds about right actually.
I'm going to take the wipers and arms off.I'll also take a roll of duct tape in case I need to seal up some of the front and streamline it.
Originally posted by talisman View PostLooking at those calculations I would only need about 10-15 horsepower more to go after the 150 club. That can't be right. On Top Gear Hammond had a 425 hp Challenger and only achieved 150.02 mph.2012 SRT8 Challenger 392 Hemi-6 speed
Resonator Delete
There is a big difference between some peak hp value measured on a dyno versus the RPM you'll actually be able to pull under a load.
So if you make 300hp at 6000rpm but can't get it to pull more than 4000rpm in top gear and pushing 25sqft through the air, then your predictions are going to be a little low
I suspect you will need an honest 325-350rwhp to hit 150mph inside of a mile.When the government pays, the government controls.
