4r70w and AODE sensors and stuff and junk
  • 4r70w and AODE sensors and stuff and junk
    Does everything plug in just the same between the two electronically? Just swap the tailshaft and the extension housing and go?
    '95 GT
    I fucked the Olsen twins before they were famous.
    why would you swap the tailshaft? just the hsg if even that
      Well Ill know once the aode is out. The trans is manualized... I guess speed sensor is probably all I have to run eh?
      '95 GT
        everything that needs to swap from one to the other, will. the differences are inside. you will need the range sensor on the driver side of the trans too
