Power steering question
  • Power steering question
    I have my current build on a run stand waiting to be test fired and broken in. I have all front dress and accessories mounted including the power steering pump. I know the P/S pump will build pressure so I thought about filling it with fluid and looping a hose from the pressure side to the return side of the pump just to circulate fluid and keep it from damaging the pump.
    So with that being said, does anyone see an issue with this? Can I do this?
    TIA
    Sent from my SM-G975U using Tapatalk
    --carlos
    Worst case you're out $75-100? Send it.
    Originally posted by stevo
    Stevo
      Hmm, I guess you're right.
      --carlos
        It should work fine.
          what's the current build?
            If you are running the A/C compressor you could run a short belt and bypass the P/S.
              306. All forged internals. X cam, Edelbrock RPM heads, Air Gap intake, and 670cfm Holley. Nothing fancy.
              --carlos
                Not running the compressor.
                --carlos
                  make sure you use ATF in the steering pump.
                    WTF? I've never heard that before!
                    --carlos
                      that's per ford. They dont use power steering fluid. it's the reason you hear the old pumps that style making noise.
                        Hmm
                        --carlos
                          I've had quieter power steering pumps when running synthetic Mercon V in them. For my '92 F-150 I swapped to a Saginaw pump from a later model van. Dead quiet & the power steering feels like a Cadillac.
                            Ok, next question. Will I damage the alternator if I use it solely for the pulley?
                            --carlos
                              Also, can someone help me with what post is for what on this solenoid? This thing has always boggled me.
                              --carlos
