92 ford mustang with a auto meter mechanical fuel gauge, the issue is the gauge reads past the full line, the gauge is not a vertical gauge but a horizontal (dont know if that matters or not). Issue is ever since i got the car the gauge just flies all the way to the right waaaaay past the full marker and stays there, even when i know the tank is not full, i do see it move up and down a slight bit when i turn on the car but not anywhere it should be. I thought it was a grounding issue so i verified the grounding and even re-wired it (since i have a areomotive fuel system) and nothing. So next thing i just swapped the sending unit inside the tank and went to turn the key and same thing, i see it move but never even close to pass the full marker. Gauge is wired as instructed....and ideas anyone?? Ill try and post a picture of where the needle sits shortly
Fuel gauge issue
I hope the link helps. I used to keep extra sending units and window switches
just for buggers like this.
Originally posted by garycrist View PostI hope the link helps. I used to keep extra sending units and window switches
https://www.stangnet.com/mustang-for...ge-wtf.501696/
Originally posted by dcs13 View PostPITA, way up in there.. I would suspect loose at frame connection though, so thats easier.
Originally posted by shumpertdavid View PostAre you sure the sending unit is the correct resistance for your gauge?
-1987-1997 Mustang Fuel Level Sending Unit Ohm Readings are approximately 22 ohms empty and approximately 145 ohms full.
and from Autometer
16 Ω Empty / 158 Ω Full
still tracing out the grounds.
