5.0 mustang motor vs Truck motor
  • 5.0 mustang motor vs Truck motor
    Anyone know The difference between the two ....h.p. and torque
    Got one out of a wrecked truck to put in your stang?
      Im thinking about it ...
        cams are different along with a slight decrease in compression
        hp i think is 380
          Cost vs just getting one from a wrecked GT?
            Engine alone, usually around $1,000-$1,200 difference.
              What years are you referring to?
                Are compression and cams worth that? Maybe so
                But like the OP I'd be interested to hear all the differences in detail. Just guessing, you'd think that the GT engine would be built to take more punishment. Stand up to being beat on a little better.
                  I could've got one real cheap . they took the truck across the scales...got 400 for the whole truck and this was the second one . So I was just wondering if it's worth getting one...
                    97-2001 Explorer 5.0 W/P heads. You might need different headers.
                      What year?
                      Are we talking new 5.0, or old 5.0???
                        new
                        2014 ish
                          Differences
                          Differences amongst Car motors
                          Truck motors more details
                          Ford 5.0L Modular V-8 specs, history, & information. Get the low down on Ford's 5.0L Coyote V-8, including performance ratings, engine design features, and the inspiration that brought the 5.0L back & better than ever. The latest rendition of the 5.0L was introduced for the 2011 model year and remains optional in the Ford F-150 and Ford Mustang.
                          F150 Coyote Engine (2011)
                          360HP @ 5500 rpm 380 lb-ft @ 4,250 rpm
                          10.5:1 Compression Ratio
                          Milder Cam Profile for More Torque at Lower RPM's
                          Cast Iron Exhaust Manifolds
                          Tuned for Towing
                          Front Mounted Oil Cooler
                          No Windage Tray
                          Front Cover Moves Alternator Further out to the Side
                          Mustang Coyote Engine (2011)
                          412 HP @ 6500 rpm 390 lb-ft @ 4,250 rpm
                          Stainless Steel Exhaust Manifolds
                          11.0:1 Compression Ratio
                          Higher Revving Cam Profile
                          Tuned for Performance
                          Bigger Oil Pump Gears
                          Coyote Motor Differences Gen 1 Coyote (2011-2014 Mustang) Gen 2 Coyote (2015-2017 Mustang) Gen 3 Coyote (2018+ Mustang)
                          Horsepower 412 Horsepower 435 Horsepower 460 Horsepower
                          Torque 390 lb-ft Torque 400 lb-ft Torque 420 lb-ft Torque
                          Displacement 4.951 Liters 4.951 Liters 5.035 Liters
                          Compression 11:1 11:1 12:01
                          Bore 92.2mm 92.2mm 93mm
                          Stroke 92.7mm 92.7mm 92.7mm
                          WRX
                            American Auto Salvage just got a 14 model truck engine in with 71k for $2000. They have a lot of flood stuff but this one was actually hit in the front. The cheapest Mustang engines I can find are $3400+ and all out of state.
                              I had a work truck with a 5.0 and that bitch would rip ass for a truck. It lost a lot when I put bigger tires on it. The numbers above only show performance at 4250 rpm. My biggest complaint was the delay in the throttle when I floored it. I wouldn’t be scared of the truck motor if I got a good deal on it. You can likely make it haul the mail with correct gearing and a good tune in a light car.
