I’m installing a crown vic front suspension in my old Chevy and it’s kicking my ass. Ive got it all up on jack stands except the front end being held up with the cherry picker. I’ve got plumbobs on all 4 corners, around a wheel stud to the outside and to the bottom with a level placed on the top two studs to make sure they are they same on each corner. I spent a good 5 hrs wriggling and measuring, I can get my diagonal measurements equal but my front to backs won’t be equal by 7/16”. Or I can get my front to back measurements the same and my diagonals will be off. Should I use a different reference point instead of the front lugs?
I marked a center line and measured the original wheel base so I know where I need to be but if so my diagonals are off 3/4”.
