DISC Brake Conversion- Power or non power?
  • DISC Brake Conversion- Power or non power?
    Well, I am seriously considering a front disc conversion for the Camaro. Damn drums just feel a tad dangerous. Can't decide if I want to go with power brakes or stay with Manual brakes. Summit Racing has a complete kit. $500.00 for non power and $750 for power. Any thoughts on this? Anyone know a better price for a kit? TIA
    How big is your cam? Will a power booster work with the vacuum that you have. If so go power.
      That is always a crap shoot with the cams and power brakes. To be honest, I am not sure if this cam would be big enough to cause problems with power brakes.
      Cam Style Mechanical flat tappet
      Basic Operating RPM Range 2,400-6,800
      Intake Duration at 050 inch Lift 244
      Exhaust Duration at 050 inch Lift 252
      Duration at 050 inch Lift 244 int./252 exh.
      Advertised Intake Duration 282
      Advertised Exhaust Duration 290
      Advertised Duration 282 int./290 exh.
      Intake Valve Lift with Factory Rocker Arm Ratio 0.520 in.
      Exhaust Valve Lift with Factory Rocker Arm Ratio 0.540 in.
      Valve Lift with Factory Rocker Arm Ratio 0.520 int./0.540 exh.
      Lobe Separation (degrees) 110
      Intake Valve Lash 0.016 in.
      Exhaust Valve Lash 0.016 in.
      Grind Number CS XS282S-10
        I went non power on my 68 Cougar and have no regrets.
          I believe that is what I willl do.
            Surely there's a hydroboost setup for first gen Camaros. My vote goes to that.
              This.
              I went non power on my mustang, dont have an issue. Non power brakes usually have more pedal leverage built in, so dont try and mix and match setups.
                non power
