Oil pressure gauge reads 0 + CEL
  • Oil pressure gauge reads 0 + CEL
    Does anyone have any suggestions for this... 07 GMC Sierra, 5.3l
    I was driving home yesterday when I noticed my CEL light came on and oil pressure gauge was reading 0. I'm not sure how long it was on other than less then 10 minutes from when I left the store. I was about 2 miles from the house so I kept driving home.
    Oil looks good. I had the oil changed 10 days ago and it appears to be fresh oil. No metal flakes but it does have tiny black specks in the oil. I'm not sure if this is normal for an engine with 190k miles.
    I think I'll chance it and run it to O'Reilly's to get the code checked. Hoping it's just a failed sending unit.
    Thoughts?
    Pretty sure it's the sending unit, my wife's Tahoe is an 03 with 215k on the 5.3 and her pressure is spiked at 80... even with the engine off but key on. It seems to be a common issue on the LS motors.
    Originally posted by stevo
    Stevo
      If it had no oil pressure it would have a nice death knock. Sending unit like mentioned
        Don't be so sure. My WS6 was showing no oil pressure on the gauge, but wasn't knocking. I drove it back to dallas from shreveport, expecting it to be the sending unit. Mechanical gauge showed 3PSI hot idle. Spun cam bearing.
        I would hook up a mechanical gauge first, just to be sure.
          Meh, just keep driving. You'll find out.
          Lol
            Bang it off the rev limiter for a couple minutes, that will fix it.
              And open header..
              "PSH!!!"
                You can get a new short block at 7-11 for $4 so drive the shit out of it.
                  Those gauges were put there for entertainment and are frivolous.
                  They are shiny.
                    On some yeare there is a filter to the AFM/DOD under the sending unit that can throw some code. Pull it out with a pick and clean if you have it. Not uncommon to eat cam bearings either
                      Common on a chevy, you will need to get a deep socket oil pressure switch socket, or a deep socket 29mm if I recall correctly.
                        Thanks for the info. It's on my list if parts stores are open in the morning. I noticed how the AFM doesn't engage now...i kinda like it that way.
                          Were all open new years day
                            All's well that ends well.
                            Replaced the sending unit, cleared the codes and all is right. I had to buy the socket, $10, but still came out less than paying the dealer. Got it done in about 30 minutes. Thanks gents!
                              I would have loaned you 1.
                              I am up the street.
