Bought a GM type HEI distributer for the 68 'stang, 351w auto. Tested it on the bench with a battery, lots of spark
Pulled out the points distributer and put it in no spark. Pulled it out and bench tested it with a battery and spun it with a roll of the fingers. Hot, blue spark. In the car again, 13.2 volts on the battery, hot wired direct to the battery, ground to the battery, crank the motor over no spark.
Pulled it out and only when I spin the distributor quickly do I get a spark, cranking speed no spark.
Any ideas guys? I went with this system as I thought it would be dirt simple and give me a hotter spark than the points.
Any suggestion on what to get if I can't get it to work. I really don't want to put in a MSD or something $$$ as this is her car and only street driven.
