We did the trans swap a long time ago. Runs and drives fine, but is it possible to get the speedo to work?
99 5 speed in a 98???
Originally posted by greenbullitt View Postrun the 98 ext hsg and make sure you install the drive gear on the tail shaft. its all a direct interchange,Josh
Like Whiteboy said, use a Speed Cal and be done with it.
for a t45? ive done it man..the angle of the hole for the vss is different (straight vs angled) but they interchange. I put a 99 in a 96. you have to watch out though, the cobras are different i know (for the mount)...i agree the speedcal is easierRing and pinion specialist
Originally posted by greenbullitt View Postfor a t45? ive done it man..the angle of the hole for the vss is different (straight vs angled) but they interchange. I put a 99 in a 96. you have to watch out though, the cobras are different i know (for the mount)...i agree the speedcal is easier
Originally posted by thesource View PostIts been a while since I have messed with a 99-up T45 but thought the area where the speedo gear rides is different as well.Ring and pinion specialist
Originally posted by greenbullitt View Postshouldnt be...you can take the reluctor off and it should accept the drive gear (at least mine did) which was from a 99 cobra
I just did this swap for a guy on here. Just swapped the reluctor for the '98 drive gear and used his '98 tail housing.2012 Silver Mustang GT 5.0:stock.
'00 Performance Red Mustang GT 4v turbo 6-speed 540rwhp/572rwtq (SOLD)
'07 Honda CB919 (SOLD)
