hey guys, I need some suggestions here. I needed to tackle a couple of things on my truck. One of them was the brakes. The rear shoes were worn and out of adjustment and caused my front rotors to warp. I've done brake jobs for my vehicles for the past 20 years. I've never had an issue with replacing pads/shoes and rotors/drums.
So, I replaced the rear drums, shoes, front pads (Wagner OEx), and turned the rotors since they were replaced 2 years ago. Put it all together and I get this vibration when braking. Almost like warped rotors but faster shaking/pulsing. Kinda like a chatter without any noise.
First thought was that Oreilly's might have screwed up turning the rotors. It was late in the day so I didn't have time to take them back up there so I bought new rotors. Put it all back together and same thing as above.
Second thought was that maybe I over adjusted the rear shoes. Jack up the rear and loosen the shoes so there's very little drag when sliding the drums on. Put it all back together and same thing as above.
By this time I call it a night.
This morning I thought, I've never tried the Wagner OEx pads before. So I put the old pads back on (Wagner Thermoquiets). Go for test drive and the noiseless chatter is still there.
Then think, loosen the shoes some more. Lift up the rear wheels and loosen the shoes a lot, try it again and no luck.
What the hell is going on here? I have new drums/shoes (O'Reilly's Brake Best Select), new rotors (Brake Best Select), new pads (Wagner OEx). I can't even tell if it's coming from the front or rear.
Like I said, I've done this many, many times. I can do them in my sleep. When depressing the calipers, I opened the MC cap to allow the fluid to fill up. Then I take an old pad and slowly depress the pistons back in. Close the cap, slowly press the peddle so the pistons expand and done.
I'm not even sure what to check any more. I've had this thing in the air 4 times now! Which is a lot when using a jack and jack stands.
