2.02 1.60 valve aluminum heads for a 302 Windsor based motor. Can some one do me a favor and if you have a set of aluminum heads around, can you measure from the center of the rocker arm stud to the center of the valve tip and give me your measurement? This is the second set of heads I've ordered from this company and I'm almost positive the holes for the rocker arm studs are being tapped in the wrong place causing to rocker arm to be too close to the valve spring, which in turn throws the rocker arm geometry completely off. Any help with be greatly appreciated!
HELP with Rocker Arm Geometry!
Originally posted by Torinoman View PostPushrod length will affect your geometry a lot. Are you using the correct length?
What makes you think the studs are placed incorrectly?
Originally posted by bird_dog0347 View PostIf I had seen this last week I could have measured on my TFS heads but I just buttoned the car up over the weekend and don't feel like pulling crap apart to open the valve cover.
New set of heads show where the rocker arm stud holes are tapped
Old set showing where the rocker arm stud holes are tapped
Tip of the rocker with huge over lap on the valve tip with what looks like somewhat close rocker arm geometry
This is when I adjusted the adjustable pushrod down far enough to get the roller tip of the rocker to be centered on the valve tip when I rotate the engine. The lock nut of the rocker is basically touching the blue part of the rocker...
I have never heard of Flowtek heads but suspect that they are Chinese castings there finish machined here in the U.S. It is the new black.
Anyway, my first takeaway from your pic is the height of the valve stem. That stem looks very high and it makes me wonder what valves are in your heads.Originally posted by racrguyWhat's your beef with NPR, because their listeners are typically more informed than others?Originally posted by racrguyVoting is a constitutional right, overthrowing the government isn't.
Originally posted by Broncojohnny View PostI have never heard of Flowtek heads but suspect that they are Chinese castings there finish machined here in the U.S. It is the new black.
I didn't even think about that... They do look really long. The company has been around for a long time and they have some pretty good reviews. I buddy of mine bought a set of heads from them about 6-7 years ago and they've been perfect ever since. But, I'm not sure sure who doing the ordering and measurements now but they're obviously sloppy about it. If I would've known this was going to happen I would've just bought a good set of used AFR's or something similar instead of dealing with them.
Originally posted by line-em-up View PostThat makes sense to me. In the photo, looks like the valve stem and rocker stud aren't parallel. If the valve is longer, then its tip will be closer to the stud.
