Buying a fox w/ a 347... want to figure out CR
Heads are TF 170 fast as cast. From what i've found all 170s are the same. I realize the motor could benefit from a larger head but hey that's what it's got with a TFS st 1 cam.
Rotating assembly:
Forged .030 Pistons
Flat-Top Piston Design- (-11cc valve reliefs)
Pro-Stock I-Beam Rods
3/8" Cap Screws
ARP 8740 Rod Bolts
3.400" Stroke Series 9000 Cast Crankshaft
5.4" Rod Length
My whole reasoning is I'd like to add boost and I'm seeing conflicting information. I have the option of 91 or E85 where I live. I see guys saying Meth is a must with higher CR and I see others say they are running pump gas tunes with greater than 10:1 CR. Seems to be no consensus and I'm pretty green to this kind of stuff.
Thanks in advance.
Rotating assembly:
Forged .030 Pistons
3/8" Cap Screws
ARP 8740 Rod Bolts
5.4" Rod Length
Thanks in advance.
