Best way to clean old Cleaning valves?
  • Best way to clean old Cleaning valves?
    Rebuilding my heads and was trying to clean a few valves and realized that chem dip, dispite having valves on the can and working flawlessly on Pistons" fails to work on hard carbon on the surface of the valves.
    Any solutions? Bench grinder with a brass wheel?
    Should I just drop them off the machine shop and have them clean them?
    Brass wire wheel has always served me good
      Try the Blue colored can of easy-off oven cleaner. It will not eat everything up.
      Killer on carbs and brass jets and baked on hard carbon stuff....
        run em as is. what are you trying to clean off them? oil? is the new motor oil-less?
        slap that shit together so i can drag that ass.
          Loll in what?
          Nah just cleaning the carbon (7k miles worth) off the valves. Not much. But they were new a few years ago.
          Clean, clean , clean...
            i have a guy with a blast cabinet with a walnut media that would do that for cheap as shit. its what we do on bmw's
              Will I get my heads back when he's done?
              Hahah
                Chuck them in a drill press and use some scotch brite pads on them.
                  Soak them in WD40 and then hit them with the brass wire wheel
                  Two in the pink and one in the stink
                    2nd for media-blast
