I have an issue with my clutch. It's really tight, but sometimes it loosens up. I can start out in 1st gear and it's fine, shift to 2nd and no problem, I engage the clutch to shift to 3rd, and it tightens up. This happens in between shifts an any gear. Is it a clutch cable problem?
Clutch Cable Tight/Loose
Sounds like it, most all of the cables are junk, I'd buy the maximum motorsports cable if you can.Interested in being a VIP member and donating to the site? Click here http://dfwmustangs.net/forums/payments.php
Sounds like the cable is binding, it's probably fraying internally somewhere.Originally posted by PGreenCobraI can't get over the fact that you get to go live the rest of your life, knowing that someone made a Halloween costume out of you. LMAO!!Originally posted by Trip McNeelyOriginally posted by dsrtuckteezydont downshift!!
Originally posted by Baron Von Crowder View Postok, Ill bite.
How do you know?My old hatch would walk trans and starter bolts out every now and then. Solid mounts and syphericals everywhere with a poly trans mount. Was afraid to use a form of locktight back then.
Just became a regular thing to check them.
