Had my battery relocated to the rear on my fox body a few years ago and have had a issue since with it draining my battery. I basically have to disconnect the battery cables every time I park it. I rarely drive it though so never really tried tracking down the issue. I want to start driving it a little more now but need to fix this issue. As of right now it has a 1 gauge positive cable going from the battery all the way up to the solenoid and a 1 gauge negative grounded down to the frame.
I charged up the battery to 100%. Connected the positive side cable to the battery and left the negative cable unconnected. Took my volt meter and switched it to DC volts and connected the leads to the negative post and the negative cable and it read 13.45. Checked the voltage at the battery and it also read 13.45. Shouldn't it be 0 between the negative post and negative cable with the positive cable connected? The ignition switch is in the off position.
