TFI module maybe? (plastic rectangle bolted to the side of the distributor) I think you mentioned replacing the distributor so not sure if that included the TFI. When mine went bad, the car would cold start fine, but after it warmed up a bit, it would die. The fact that rotating the distributor SEEMS to help could be its slightly flexing the TFI and making it work temporary.
Foxbody starting problems
Originally posted by TRAXX View PostTFI module maybe? (plastic rectangle bolted to the side of the distributor) I think you mentioned replacing the distributor so not sure if that included the TFI. When mine went bad, the car would cold start fine, but after it warmed up a bit, it would die. The fact that rotating the distributor SEEMS to help could be its slightly flexing the TFI and making it work temporary.
Originally posted by 86lxttop View PostYes I've tried all of that...Interested in being a VIP member and donating to the site? Click here http://dfwmustangs.net/forums/payments.php
