2009 F150 with 5.4L 3V - ticking sound
  • 2009 F150 with 5.4L 3V - ticking sound
    Friend at work has one that makes a ticking sound almost all the time. It's worse after driving the truck, shutting it off (stopping at store, etc.), then starting it back up. Then the motor actually shakes, along with the ticking.
    Dealer said it's a common issue and quoted $4,000 to fix it.
    Does anyone here have experience fixing that for a more reasonable price?
    This is what I found online, but it suggests several culprits:
    TICKING AND / OR KNOCKING NOISE / STARTUP TSB 06-19-8
    RATTLE FROM ENGINE—4.6L / 5.4L 3V
    FORD: LINCOLN:
    2005 Mustang 2005 Navigator
    2004-2005 F-150
    2005 Expedition, F-250, F-350
    This article supersedes TSB
    06-4-7 to update the NOTE
    Service Procedure. THE 4.6L 3V AND 5.4L 3V ENGINES ARE
    INSTALLED IN SEVERAL VEHICLE PLATFORMS,
    ISSUE
    WHICH MAY INFLUENCE THE INTENSITY OF
    Some vehicles equipped with a 4.6L 3-valve or 5.4L NOISE DUE TO VEHICLE DIFFERENCES IN
    3-valve engine may exhibit a ticking and / or SOUND TRANSMISSION PATHS, HOOD AND
    knocking noise after reaching normal operating BODY INSULATION PACKAGES, AND ROOT
    temperature, or a rattle upon starting. The noise CAUSE OF THE COMPONENT(S) CAUSING THE
    may be described as ticks, taps, knocks, or thumps. NOISE.
    In some cases the noise may be a normal
    characteristic of these engines. In other cases the
    PRE-CHECKS
    noise may require further investigation. Sorting out
    1. Make sure you have a detailed description of
    and defining the noise as reported by the customer
    the noise the customer is concerned with,
    is important to successfully diagnose and / or repair
    including whether the noise is occurring at idle
    the condition.
    or above idle speed (does it disappear above
    ACTION
    1200 RPM), and if the engine is cold, hot, or
    Before starting diagnosis, it is critical to determine both when the noise is occurring. These
    the specific engine noise the customer is concerned engines generate a lot of “normal” noises, so it
    with. The customer should be interviewed to get is critical to confirm the noise the customer is
    their detailed perception and description of the concerned with. Determine what environment
    noise, and to determine if the noise occurs at idle the customer is in when the noise is most
    or above idle speed, and if the engine is cold, hot, noticeable to them (inside passenger
    or both. Attempt to duplicate the noise, and compartment, next to building with / without the
    determine the source of the symptom. Refer to the driver and / or passenger window open, or
    following Service Procedure to help determine the beside the wheel well). Validate by using your
    source of the noise and if a repair is needed. own perception.
    SERVICE PROCEDURE
    2. Compare the noise generated with a new
    vehicle, if available, with an ENGINE build date
    NOTE
    of 3/30/2005 or later on Mustang and 4/18/2005
    READ THIS SECTION IN ITS ENTIRETY BEFORE or later on F-150 to F-350, Expedition and
    BEGINNING. Navigator vehicles.
    3. Diagnose noise when engine is at normal
    operating temperature (Oil at 160
    ° F (71° C) or
    above). Verify oil temperature by using a
    diagnostic scan tool and monitoring the engine
    oil temperature (EOT) PID. Startup rattle may
    only occur with cold oil.
    NOTE:
    The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do
    the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper
    vehicle service. The procedures should not be performed by “do-it-yourselfers”. Do not assume that a condition described affects your car or truck. Contact a
    Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation
    determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin
    (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is
    available through Ford Motor Company’s on-line technical resources.
    Copyright
    ã 2006 Ford Motor Company Online Publication Date September 13, 2006 PAGE 1
    TSB 06-19-8 (Continued)
    4. Check the type of oil filter installed on the VCT phasers may knock at hot idle. It may be
    vehicle. A dirty or clogged filter may cause a heard inside the passenger compartment, or the
    pressure drop. Look for aftermarket brands not wheel well area. Some light noise is normal. The
    recognized in the market or a production filter engine may require a cold soak overnight for a full
    that has gone beyond the standard Ford diagnosis to effectively be made at hot idle,
    recommended change interval. particularly when a VCT phaser is suspected. The
    knock is not prevalent at cold temperature.
    5. Check for signs of oil brand used and viscosity
    (interview customer if needed). Motorcraft
    â To test for VCT noise:
    SAE 5W-20 Premium Synthetic Blend Motor Oil
    or equivalent is recommended. 1. Place the transmission in park or neutral
    Once the above pre-checks are complete, check 2. Bring engine oil temperature to 160
    ° F (71° C)
    for sound level from the following components, in or above as indicated by the scan tool “EOT”
    the order listed. Compare the sound from these PID.
    components to the noise the customer is concerned 3. Allow engine to idle, and determine if noise is
    with, to determine the source of the noise. noticeable.
    INJECTION / FUEL SYSTEM
    4. Set engine speed to over 1200 RPM (if noise is
    Injector noise (ticking) is considered normal. Noise a VCT knock, the noise should disappear).
    increases with RPM hot or cold and is recognized 5. Return engine speed to idle (verify knock
    at the top of the engine. returns).
    VALVE TRAIN
    If the noise intensity is more than a lightly audible
    Lash adjusters can make a ticking / tapping noise knock at hot idle under 1200 RPM at engine
    noticeable at any engine RPM / temperature and is operating temperature, replace the cam phaser
    audible through the wheel well or an open hood. using the “In-Vehicle Repair” Camshaft Phaser and
    However, with the hood down, lash adjuster noise Sprocket procedure found in the Workshop Manual,
    can be heard as a light tapping noise through the Section 303-01
    wheel well and is considered normal.
    START UP RATTLE
    Tracing this noise must be isolated to a cylinder Some 2004 F-150 and 2005 F-150, Expedition,
    bank. If one bank is louder than the other bank, Navigator, F-Super Duty, and Mustang vehicles may
    focus the diagnostic to the loud bank. If both banks have a rattle on startup that lasts 1 to 3 seconds. If
    seem loud with the hood down, compare wheel well initial pre-checks have been completed and the
    sound level to another comparable vehicle. noise sounds like it is coming from the front of the
    Use a stethoscope on the top of the cam cover bolt engine, replace the VCT Phaser Kit. If the engine
    heads to confirm which bank is affected. Move the continues to make the rattle noise after the initial
    probe from front to rear if necessary. startup do not exchange VCT.
    If isolated, only replace the intake and exhaust
    PART NUMBER PART NAME
    lifters on the affected cylinder bank.
    5L1Z-6500-AA Lash Adjuster (2005 Vehicles)
    3L3Z-6500-BA Lash Adjuster (2004 Vehicles)
    VARIABLE CAM TIMING
    3R2Z-6A257-DA VCT Phaser Kit
    The 4.6L 3V and 5.4L 3V variable cam timing
    (VCT) feature may emit a light knock in normal
    Last bit:
    WARRANTY STATUS: Eligible Under Provisions Of
    operation and is audible only at idle speed, with a New Vehicle Limited
    hot engine (gear selector in park / neutral). Warranty Coverage
    However, it may be masked by or mistaken for
    other noises generated from either injector firing or
    a malfunctioning valve train as described above.
    The noise does not affect performance or durability
    of the part.
    PAGE 2
    OPERATION DESCRIPTION TIME
    061908B 2005 Expedition / 2.7 Hrs.
    061908A 2005 Expedition / 4.5 Hrs. Navigator 5.4L 3V:
    Navigator 5.4L 3V: Replace Left Bank Lash
    Replace Right Bank Lash Adjusters And / Or
    Adjusters And / Or Camshaft Sprocket /
    Camshaft Sprocket / Phaser (6500A, 6256A,
    Phaser (6500A, 6256A, 6250A, 6020A, 6268B,
    6250A, 6020A, 6268B, 6266A, 6584A, 9424A)
    6266A, 6584A, 9424A) 061908C 2005 Expedition / 6.7 Hrs.
    061908A 2005 Mustang 4.6L 3V: 2.2 Hrs. Navigator 5.4L 3V:
    Replace Right Bank Lash Replace Both Banks Lash
    Adjusters And / Or Adjusters And / Or
    Camshaft Sprocket / Camshaft Sprocket /
    Phaser (6500A, 6256A, Phaser (6500A, 6256A,
    6250A, 6020A, 6268B, 6250A, 6020A, 6268B,
    6266A, 6584A, 9424A) 6266A, 6584A, 9424A)
    061908A 2005 Super Duty 5.4L 3V: 3.1 Hrs. 061908C 2005 Mustang 4.6L 3V: 4.2 Hrs.
    061908A 2004-2005 F-150 5.4L 3V: 3.7 Hrs. 061908C 2005 Super Duty 5.4L 3V: 5.2 Hrs.
    061908B 2004-2005 F-150 5.4L 3V: 2.5 Hrs. 061908C 2004-2005 F-150 5.4L 3V: 5.5 Hrs.
    Replace Left Bank Lash Replace Both Banks Lash
    Camshaft ) Sprocket / Camshaft Sprocket /
    6266A, 6584A, 9424A 6266A, 6584A, 9424A)
    061908B 2005 Super Duty 5.4L 3V: 2.6 Hrs. MT061908 Claim Additional Labor Actual
    Replace Left Bank Lash Required As Actual Time Time
    Adjusters And / Or
    DEALER CODING
    Camshaft Sprocket / CONDITION
    Phaser (6500A, 6256A, BASIC PART NO. CODE
    6250A, 6020A, 6268B, 6500 (LASH ADJUSTER
    6266A, 6584A, 9424A) REPLACEMENT) 42
    061908B 2005 Mustang 4.6L 3V: 2.3 Hrs. 6A257 (VCT REPLACEMENT) 42
    Adjusters And / Or
    Camshaft Sprocket /
    Phaser Hrs. (6500A,
    9424A)
    Thanks in advance for any help.
      Im going to guess it's got 80-110k on it now?
        isnt it like the cam phasers or something? mine did the same thing.
          I believe she said 60,000, but can verify.
          That's one option I've heard, not sure what the dealer quoted.
          They would like it fixed, but since it's apparently a common issue, they are hopeful there's a better solution than writing the dealer a $4,000 check.
            interesting, they usually wait a bit longer.
            It's the cam phasers almost every time. I had a buddy's dads truck in a few months ago that went out at 85k, paid the dealer ~4600 to have it fixed, and it was back 11k later. The oil passages get plugged up in the block, and the phasers go out. We put a reman longblock in for him for about the same money the dealer charged for what they did.
            There isnt a perfect way to prevent it, but using motorcraft or wix filters helps a lot.
              Lot of info when searching f150 and cam phasers
              Originally posted by MR EDD
                Yep, sounds like phasers. Mine finally got bad enough around 120k that i just traded it in on my '13.
                  Am I understanding correctly that for someone who isn't mechanically inclined, eating the cost and using better oil/filters in the future is the way to go? No mechanics on here are interested in the job?
                  I appreciate the advice - I'm clueless on the truck stuff.
                    I did the same with mine at 130k
                      Job isn't that hard. I just did it on a family members 08 with 90k, Parts alone were about 900 for timing chains, guides,phasers and actuators. It had a bad phaser and broken timing chain guide but truck still ran great on highway it just ticked and had a rough idle. You don't have to discharge Ac either you can just lift pass side valve cover enough to get the phaser and actuator out, driver side is easy.
                        If you're lucky it's just phasers, if not then the cam saddles are scored. Make sure you use exactly the specified weight/grade of oil.
                          I can do it. I am not on here very often lately. Pm baron and he can quote it
                          Thanks
                            Thanks
                            PM sent (to him), thanks!
