SO... I have picked up an electric golf cart, removed batteries, installed a 420CC harbor freight gas engine. Everything is good to go except my fuel. The take im guessing is gravity feed, but because of the way its set up, i cannot install the tank above the seat, so ... im adding a fuel pump..
I bought a fuel pump off amazon - 3-5lbs... I cannot figure out how to wire the thing. It has a hot line and a ground. I hooked the + up to the battery and the ground gets HOT and it sparks bad.. so , common sense tells me something isnt right. Help
Thanks ,
Hector
Thanks ,
Hector
